Hi to all,
i want to use mailgun as smtp server for sending my emails but i'm unable to do it.
I've tried to configure it in all the ways possible but when i send an email test it waits a minute and then returns a page 404 error. I tried with acymailng 5 and 6 but it's the same thing.
With the same configuration the site sends emails like a charm.
Acymailing configuration:
Error returned:
Global site configuration:
Thank you in advance for an answer
Fabi
Hi, the error says that you can´t connect with this settings. Try to change the SMTP settings - also the SSL/TLS.
Thank you so much for your response. I tried with all the possible combination of settings. The strange thing is that the site sends emails with this setting (Test, Contact form, etc.)
Do you mean only some specific emails are not being sent?
This can be due to the content / campaign settings (sender name etc)
Maybe you can do some tests such as splitting your email to see if some content cause the email to be blocked?
Regards,
Alexandre
  • fabi replied to this.
    Alexandre I can't send any email. Also sending test-email. Thanks
    Please email us using our contact form. We will have a look at it ;-)
    Don't forget to mention this thread URL in your email
