GgalburSupport Beginner
When i try to test the Acymailing Subscription Form i got the follwing message:
The form could not be submitted ReferenceError: submitAcymForm is not defined
Thank you
Christoph
Thank you
Christoph
@galbur The issue usually comes from the development mode, when you activate it the function which add script wait for the template to load the javascript.
In the development mode the template is not called and the scripts are not called either.
Hi
Thank you. What exactly is the development mode and how can i disable it?
All the best
Christoph
@galbur : Please check it under your active template's options
Hi
I can't see any development mode. Are you talking about the Joomla! Templates?
