knowledge Hi, i have problem with the choice of users based on an advanced SQL query when i select this choice and i write SELECT from a query does not work what can i do for that i follow all the instructions but the problem exist.
mihha I honestly don't know what else to say here. I can only state the most obvious. Try to fix your SQL query. You would really need to provide more details about the problem if you would like to receive more helpful advice, I am afraid
