zshaw Hello! I have a custom PHP script, which i would like to use to trigger an automation. What is the best way to do that? Thanks!
mihha You can't trigger automation using PHP script The only way to trigger automation is using cron job URL
zshaw Update: I was able to accomplish what I needed after finding the page below. https://docs.acymailing.com/developers/acymailing-developer-documentation#code-api-for-quick-integration
