Hello
I see how to insert Joomla articles ad other tags (as "Read it online”...) using Acymailing editor, but how to using the site editor?
Thanks
How to insert Joomla articles using site editor?
jvstratumSupport Senior
To insert tags using the html editor they must be added manually. Dynamic text tags can be found in the bottom of the design panel in the drag & drop editor.
If you are looking for tags used for articles, please add the articles in the drag & drop editor and inspect the HTML of the block. To do that, select the block, scroll down in the right-hand panel and click on the "Edit HTML" button.
Please note that certain tags may not work in the HTML editor, especially for add-ons. We strongly recommend getting familiar with the drag & drop editor, as it is the future of Acymailing.
