Hello.
I have been using acymailing for years and years and I have never been able to configure the bounce system correctly.
The last attempt was made a few months ago.
With Gmail, but we still get this error message.
` CIRÉ ASBL no-reply@cire.be
Aujourd’hui, 13:20Webmaster
AcyMailing déclenché à 29 Septembre 2023 13:20
Gestion des rebonds : Retrying PLAIN authentication after [AUTHENTICATIONFAILED] Invalid credentials (Failure)
Can not authenticate to IMAP server: [AUTHENTICATIONFAILED] Invalid credentials (Failure)`
And the parameters are
https://i.imgur.com/2sUF3vJ.png
What can we do to fix it...?
Thank you.
Best regards.
Hello.
Thank you for your answer.
So we NEED to enable the Two Factor Authentication ?
If not, it'll never work ?
Best regards.
