Hello,
I am using AcyMailing with multilingual emails enabled, and language-based delivery itself works correctly.
My site is already fully built as a multilingual site using FaLang, and switching to Joomla’s native multilingual system is not an option at this stage.
When I add an Article block to the email content and configure it to display the latest articles from a category, the block always displays the default language articles, regardless of the email language.
I would like to clarify the following points:
1. Is the Article block designed to support multilingual articles managed by FaLang?
2. If FaLang is not supported, is there any recommended way to use AcyMailing with FaLang-based multilingual sites when article content needs to be included in emails?
(For example, alternative blocks, recommended workflows, or known limitations.)
3. If no such solution exists, is it correct to understand that the Article block cannot be reliably used in FaLang-based multilingual environments?
Since FaLang is already deeply integrated into our site, understanding the intended or recommended usage of AcyMailing in this context is very important for us.
Thanks
